F-22 vs. Rafale dogfight
zero-one wrote:
to be fair, I don't see a reason why we should doubt their supercruise claims. Put enough thrust on a brick and it will go super sonic. just look at the F-4![]()
I think a Rafale and Typhoon still has substantially less drag and more thrust to weight than the F-4 even if it had a bag and 4 missiles.
Its not unreasonable to think that they can break the barrier with AB and maintain Mach 1.2 in Max mil power at certain altitudes. 40K maybe
Sure it's fair.........Jon Beesley once said even the Amraam (AIM-120) had a big impact of flight performance. In addition the weight and drag of an external fuel tank. Is so high that it consumes half of the fuel held within.
Which, is not to say the Rafale can't. Just saying we have good reason to question the claim....
![Wink :wink:](./images/smilies/icon_wink.gif)
Also, let's say for the sake of argument. The supercruise claim of Mach 1.2 with missiles and tanks is accurate. The drag would still be considerable and even on military power. Would consume a great amount of fuel.
In short the duration would likely be very short....![Wink :wink:](./images/smilies/icon_wink.gif)
Well, the Rafale and the Typhoon carries the missiles in tandem and semi-recessed and that is a lot of less drag than (a pylon and) a AMRAAM under the wing. Also the Typhoon is slender compared to the F-35 and adding extra cross section to the F-35 punishes it more than the Eurofighter. (remember the added area is both pylon and Missile)
Also if you look at the Rafale tanks they are arearuled to minimise the cross sectional area. This minimizes supersonic drag, so for me it's highly plausible that they can go supersonic with bags and missiles, and perhaps even supercruise at some altitudes.
And... You always use AB (or a dive) to go through transonic unless you have extremely much excess power dry.... don't know of any airplane that likes to stay in the transsonic regime.
regards
Finally someone qualified does a factual review of this video:
Very interesting.
I was surprised to see that Rafale managed to get a lock on the F-22 several times. I remember reading about F-15 pilots complaining that they could not get a lock on the F-22 even when it was close enough to be eye-balled.
Also this was back in 2009. Rafale has much improved sensors since then, both radar and optical, so it will be able to obtain a lock at even greater distances with the latest updates. Of course Rafale would still not get close enough unless the F-22 pilot makes a mistake.
loke wrote:Very interesting.
I'm almost certain that Raptors had Luneburg Lenses installed during these training events, which would make it easy for the Rafale's radar to detect it. Plus it was very close range as ATE pointed out. Just a guess but it appears that the Raptor driver was a lower experienced pilot. Made some pretty big errors. As always, it boils down to the man (or woman) in the crate and not the crate itself.
When it comes to fighting Raptors, "We die wholesale..."
BDF wrote:loke wrote:Very interesting.
OK Luneberg lenses is probably the explanation -- so when the F-15 pilot could not get a lock in spite of being very close range perhaps the F-22 was flying without? Or with "smaller" Luneberg lenses?
Rafale also has IRST with laser rangefinder.
sprstdlyscottsmn wrote:Rafale also has IRST with laser rangefinder.
Exactly. There is no practical way of defeating IRST or laser rangefinder at close ranges. Rafale also has - which will also see and track F-22 at close ranges if the Rafale pilot can point his aircraft towards it. Rafale also has possibly the most advanced sensor fusion system in 4th gen fighter aircraft, which likely would also help.
Rafale is definitely very dangerous adversary even against F-22 if the fight goes to WVR dogfight. It's powerful and maneuverable aircraft which has advanced avionics systems and nice array of sensors. F-22 is even more powerful and maneuverable overall, but I bet the room for error is rather small in this environment. Of course F-22 pilots would avoid any WVR combat in real combat, unless absolutely necessary.
hornetfinn wrote:sprstdlyscottsmn wrote:Rafale also has IRST with laser rangefinder.
Excellent points. I think that with the future F4 upgrades just around the corner the Rafale will keep a significant edge over any non-Western a/c for quite some time to come. Perhaps J-20 will be the only one that could potentially give the Rafale a hard time in the medium time frame?
loke wrote:BDF wrote:loke wrote:Very interesting.
In US exercises, F-22/35s don't need to use Luneberg lenses, but when training overseas, they absolutely will.
zero-one wrote:At the end tho, Ate was asked which fighter would he take into an air superiority mission. He said if you will train me in an F-22, I'll take the F-22
There is no question about that. F-22 is currently in a league of its own when it comes to actual air superiority missions. It has VLO stealth, Mach 1.8+ supercruise, great maneuverability in all speed and altitudes along with very powerful radar and EW system. No other fighter aircraft has all those attributes. I see currently only F-35 being able to compete due to also having VLO stealth and even more comprehensive sensor suite along with more advanced sensor fusion and networking.
But when it comes only WVR dogfighting, then Rafale is one of the best 4th gen fighter aircraft around. It's powerful and maneuverable (like F-16 Block 50 or slightly better) and has possibly the best and most comprehensive sensor suite of all 4th gen fighters. I can see it being tough opponent even for F-22 in WVR dogfight exercises. But like all other 4th gen fighters, it would not fare well in real world combat against F-22.
Users browsing this forum: No registered users and 24 guests
